Put an ad in the "parts wanted" section of the forum. If someone has a 235 block they're about to scrap out, the main bearing bolts are the same as the 261. I believe main bearing bolts for a 216 will work, also. Occasionally, I see main bearing caps and/or bolts on Ebay, so check there, also.
