9 members (MickeyP, papas52, Biermann, Otto Skorzeny, Donf, jmoore, Shade Baby, TS3600, BC59),
118
2
Mod | | | Forums66 Topics128,162 Posts1,056,949 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2019 Posts: 25 'Bolter | | 'Bolter Joined: Aug 2019 Posts: 25 | I have a rod that runs from the emergency brake pedal in the cab to under the cab and stops. Then there are cables that run out of each wheel to a mounting point on the frame and they both stop there. I believe there must be a piece that runs across the frame that ties all of this together. Does anyone with this setup have any pictures you can send me to give me an idea of what I'm missing? I've also looked all over the internet for these cables and any other parts but I have had no luck more than brake shoes and springs... | | |
