Originally Posted by WE b OLD
This is what Langdon says about the 32/36. Also says that need to be installed in pairs.
The web page doesn't state it needs to run as a dual carb setup, the 32/36 can be ran in a single configuration on a stock manifold. I talked to Langdon when I ordered it because I had a question about the linkage.
1951 Chevy 3100 1/2 ton (1957 235, 4 speed, 411 rear)
