| Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,778 | A couple of Ford-type starter solenoids can be used to fabricate a series/parallel system where both batteries run and charge on 6V and are only run in series during starting. That system has been used as a 12/24 volt setup on big Diesel trucks in cold climates for over 60 years that I can remember, and probably long before that. Jerry
