| Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,852 | All you usually need to do is rev the engine once. Most alternators will "self-excite" once the speed goes a little above idle. You can attach a wire to the terminal you're using to "excite" things from the ignition switch, or if you're not comfortable keeping the voltage on it all the time, use a push button starter switch. I'd recommend keeping the reference voltage on it all the time the key is turned on. Jerry
