| | | Forums66 Topics128,191 Posts1,057,348 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2015 Posts: 11,177 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,177 | I think you'd have to route the right side exhaust to directly below or very close to the frame rail (the standard one on the driver's side is just inboard of the frame rail and a few inches below it. The spare carrier vertical bolts are a bit inboard of the frame. There have been diagrams posted here of the '51 and later spare carrier that would help you visualize how the exhausts would have to run.
