| | | Forums66 Topics128,114 Posts1,056,283 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | The joints at each end have cups and springs that fit around a ball. The ball on the pitman arm and the ball on the steering arm are permanently mounted, and they are not easy to remove. You should take them apart and see if the balls are worn. That way you will know what needs to be done. | | |
