If you do any welding to correct your problem I would suggest that you drill, pin and plug weld as this is not an area for shoddy craftmanship, you do not want that sucker coming apart on you. Most of the time I see the pros notching the crossmembers before they mess with steering componants. Just my thoughts smile ......Dale
1939 GMC
1953 HD PANHEAD
1930 Chevy 3 window coupe
