| | | Forums66 Topics128,051 Posts1,055,730 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,771 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,771 | Any machine shop worthy of the name should be able to make things like that. It looks like you need to find a better machinist. Once the rough-poured bearings are in place, you'll still need to line bore them to fit the crankshaft. Can the shop you're dealing with do that? All the poured main bearings I've ever worked with, like Model T and Model A Ford engines, have the Babbit metal poured directly into grooves in the block, using molds designed for that purpose. Jerry
