0 members (),
78
12
Mod | | | Forums66 Topics128,021 Posts1,055,355 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,746 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,746 | You'd better explain "lapping", Evan- - - - -some of these young sprouts have never heard that term! I've still got a few tins of Clover compound, but I've been using Prussian Blue to check seat width instead of lapping valves for the past 20 years or so. Try filling a combustion chamber with alcohol sometime and see which valves leak- - - -the lapped ones don't seal as well as ones with the ground finish only. Another slick trick is to use vacuum on the intake and exhaust ports to check for a good valve/seat seal. Jerry
