7 members (Donf, Gdads51, 55shaker, TUTS 59, Forty9, Donsz, Gray_Ghost),
126
1
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,056 Posts1,055,799 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2018 Posts: 34 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2018 Posts: 34 | I'm still looking for the casting code on the block but the date code is K163. I need to pull the valve cover to get the date code on the head -- it leaks so bad so I've delayed in doing this. Will do this weekend.
b2-887-066-570 ??? where did you find that code? --- It's on the head between spark plugs 2-3
The valve cover is attached with 2 acorn nuts.
Just fyi - truck vin is 21kp19244
Mike
1952 -3100 with '52 235 Iowa farm truck "Cecil" | | |
