Register Log In
The Stovebolt Site Forums The Shop Area Driveline "Patricks' Tech Tip Article for 3.55 ring and pinion conversion
Forums Active Threads
2 members (Hotrod Lincoln, klhansen), 119 guests, and 2 robots.
Topics128,127
Posts1,056,357
Members48,441
Re: "Patricks' Tech Tip Article for 3.55 ring and pinion conversion
posey #1318283 07/18/2019 7:05 PM
Jarvisburg, NC, USA
tclederman Offline
tclederman
Offline
Jarvisburg, NC, USA
While you are waiting for leads/replies, Check out Chris Sweet's Tech Tip here, on Stovebolt.com.
Here is another Stovebolt.com Tech Tip.
Tim
1954Advance-Design.com
1954 3106 Carryall Suburban
1954 3104 5-window pickup w/Hydra-Matic
The 216 and early 235 engines are not "splash oilers" -- this is a splash oiler.
Copy Link to Clipboard
Entire Thread
Subject Posted By Posted
"Patricks' Tech Tip Article for 3.55 ring and pinion conversion posey 07/18/2019 6:49 PM
Re: "Patricks' Tech Tip Article for 3.55 ring and pinion conversion tclederman 07/18/2019 7:05 PM
Re: "Patricks' Tech Tip Article for 3.55 ring and pinion conversion posey 07/18/2019 7:34 PM
Re: "Patricks' Tech Tip Article for 3.55 ring and pinion conversion tclederman 07/18/2019 7:39 PM
Re: "Patricks' Tech Tip Article for 3.55 ring and pinion conversion Mother.Trucker 07/18/2019 9:37 PM
Re: "Patricks' Tech Tip Article for 3.55 ring and pinion conversion bartamos 07/18/2019 11:07 PM
Re: "Patricks' Tech Tip Article for 3.55 ring and pinion conversion Mother.Trucker 07/19/2019 3:52 AM
Re: "Patricks' Tech Tip Article for 3.55 ring and pinion conversion tclederman 07/19/2019 12:58 AM
Re: "Patricks' Tech Tip Article for 3.55 ring and pinion conversion bartamos 07/19/2019 1:50 AM
Re: "Patricks' Tech Tip Article for 3.55 ring and pinion conversion tclederman 07/19/2019 2:48 AM
Re: "Patricks' Tech Tip Article for 3.55 ring and pinion conversion bartamos 07/19/2019 7:43 AM
Re: "Patricks' Tech Tip Article for 3.55 ring and pinion conversion SWEET 07/19/2019 11:38 AM
Re: "Patricks' Tech Tip Article for 3.55 ring and pinion conversion posey 07/19/2019 12:35 PM
Re: "Patricks' Tech Tip Article for 3.55 ring and pinion conversion showkey 07/19/2019 12:36 PM
Re: "Patricks' Tech Tip Article for 3.55 ring and pinion conversion tclederman 07/19/2019 1:03 PM
Re: "Patricks' Tech Tip Article for 3.55 ring and pinion conversion Dragsix 07/19/2019 1:07 PM
Re: "Patricks' Tech Tip Article for 3.55 ring and pinion conversion Justhorsenround 07/19/2019 1:13 PM
Re: "Patricks' Tech Tip Article for 3.55 ring and pinion conversion tclederman 07/19/2019 1:20 PM
Re: "Patricks' Tech Tip Article for 3.55 ring and pinion conversion posey 07/19/2019 1:31 PM
Re: "Patricks' Tech Tip Article for 3.55 ring and pinion conversion Grigg 07/19/2019 1:47 PM
Re: "Patricks' Tech Tip Article for 3.55 ring and pinion conversion posey 07/19/2019 5:54 PM
Re: "Patricks' Tech Tip Article for 3.55 ring and pinion conversion SWEET 07/19/2019 8:50 PM
Re: "Patricks' Tech Tip Article for 3.55 ring and pinion conversion posey 07/22/2019 9:44 AM
Re: "Patricks' Tech Tip Article for 3.55 ring and pinion conversion Grigg 07/23/2019 12:25 AM
Re: "Patricks' Tech Tip Article for 3.55 ring and pinion conversion showkey 07/22/2019 11:35 PM
Moderated by  Dusty53, SWEET
Switch to Flat Mode
Show Likes
View Profile
Private Message
Website
Follow User
Forum Posts
Forum Rules · Mark All Read Contact Us · Forum Help · The Stovebolt Site
