| | | Forums66 Topics128,021 Posts1,055,372 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2019 Posts: 122 'Bolter | | 'Bolter Joined: Apr 2019 Posts: 122 | Mike, Thanks for the reply.
Yes, it has the center mounts. I think there is tightening nut and bolt missing off the center piece though. I saw the thread where you gave your measurements. That helps. Could you take a picture of the dog bone mounted on the truck?
I wanted to read the install instructions if someone has them to make sure I have everything and how to adjust and install it correctly.
My visor came disassembled. If anyone knows what holes they used on the metal rods, that would help me on the width adjustment.
Thanks, Joe
1951 Chevy 3100 1/2 ton (1957 235, 4 speed, 411 rear) | | |
