If $ is important, I would just replace the 6 volt starter with another. They will last forever on 12 volts if you don’t go crazy with the time spent cranking it. Replacing the flywheel and putting in a 12 volt starter could get pricey if you can’t do it yourself. JMO 🛠
Martin
‘65 Chevy Biscayne (Emily)
