| | | Forums66 Topics128,071 Posts1,055,901 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,777 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,777 | It sounds like one or both of the headlight connectors is mis-wired, using the ground pin of the 3-prong connectors as either high or low beam. That would allow voltage to back up through the indicator light circuit and keep the light on all the time, while still allowing the headlights to function almost correctly. I've seen this happen occasionally when a new wiring harness was installed by someone without a lot of experience at rewiring a vehicle. Jerry
