If the motor mounts are at the same longitudinal position on the left and right, you have a 250. If the passenger side motor mount is forward of the drivers side mount, you have a 292.
While its hard to beat this forum, the ones at
http://www.67-72chevytrucks.org/ are more specific to your truck. Good luck!
