| | | Forums66 Topics128,070 Posts1,055,892 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,777 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,777 | That's a bellows-type thermostat. As the coolant heats up air inside the bellows expands and opens the disc valve. They work best in cooling systems with very low or no-pressure radiator caps. I'd consider a 7 lb. cap to be about maximum for that type of stat and a 4# would be better. Higher pressures tend to make them stick open or closed. Jerry
