0 members (),
160
Mod | | | Forums66 Topics128,149 Posts1,056,818 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2004 Posts: 6,228 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,228 | Checking the trans gear ratios is easy...mark both input and output shafts and the housing with a reference mark. Then turn the input shaft and count it's number of revolutions until the output shaft has made one complete turn...then do this for the other gears. Direct will be one full turn of the input equals one full turn on the output. If you have OD than about three quarters of a turn on the input shaft will equal one full turn on the output. Hope this make sense, Mike B  | | |
