| | | Forums66 Topics128,049 Posts1,055,635 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | This is the list from one of my 235 conversions in a 1936. Check your PM for more info.
• 1946-47, 4 speed, front bearing retainer
• 1938-47 truck bellhousing
• 1938-39 pass clutch fork
• 1942-53 Flywheel
• 1938-54, Clutch disc & pressure plate 9”
• 1937-48 Valve cover
• 1941-52 Water pump, with my adapter.
• 1949-54 Powerglide, 4 field starter
• 1937-51 Fuel pump
• 216 distributor with 235 gear
• 235 carb
Picture of front mount modification, as a 235 is shorter than the 36 engine.
See the USA in your vintage Chevrolet! My Blog | | |
