0 members (),
297
6
Mod | | | Forums66 Topics128,162 Posts1,057,042 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,871 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,871 | If you're not planning on doing "real truck" stuff you can soften the ride by removing a few leaves from the 3/4 ton springs. That would be a lot simpler than trying to do a swap of major components like complete spring packs, etc. Leave the main leaf in place for mounting purposes, and remove a few of the shorter, stiffer upper leaves. You can also soften the ride somewhat by using thin Teflon strips between the spring leaves to let them slip past each other more easily. Some of the "resto-modded" Cowboy Cadillacs never see a load heavier than an iced-down Yeti cooler on the way to a tailgate party- - - - -heavily padded to avoid putting scratches in the glossy-varnished Mahogany bed wood with chromed hold-down strips. Jerry
