I drilled the shaft and handle out and installed a cut down cotter pin, then filed it down. It worked great!
Now for the inner handle spring back. Should I try another round of cleaning and lube? I looked at the spring when I had it disassembled before and it looked ok. Does the tension on those springs wear out?
I have a new spring I can install.
One other odd thing.
If I lock the door from the outside with the key, I can unlock the door with the key.
If I lock the door from the inside with the remote, I can't open the lock from the outside with the key.
What could that be?
1951 Chevy 3100 1/2 ton (1957 235, 4 speed, 411 rear)
