9 members (TooMany2count, Opelika Tom, Otto Skorzeny, 78buckshot, TrknGMC, Charles in CA, MikeE, Wayne67vert, TexasA&M48Truck),
59
0
Mod | | | Forums66 Topics128,091 Posts1,056,037 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,792 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,792 | Anything that allows the terminal voltage to go above 15 will overcharge- - - -the low-current "maintainers" just take a little longer to fry a battery than a 60 amp boost charger. I have zero experience with the truly sealed batteries like the Optima series, so I'll let someone else pontificate on those things. Whenever possible, I like to use batteries I can actually test- - - -ones with vents and fill caps so I can stick a hydrometer in there and check the acid concentration. If that's not possible, monitoring the open circuit terminal voltage is about the only way I know to check a battery's state of charge. To actually determine if it will get the job done, do a load test. In my somewhat biased opinion, a battery's worst enemy is lack of exercise. If your hangar queen does nothing but decorate the garage for weeks or months at a time, at least go out there a couple of times a month, turn the headlights on for a couple of hours, turn then off, and connect a slow charger with about a 5-amp maximum charge rate to it. Leave the charger connected overnight. The discharge/recharge cycle will keep the battery functional so it doesn't develop crystals of lead sulfate that are almost impossible to dissolve. Normal lead/acid battery discharge turns both positive and negative plates into lead sulfate as they react with sulfuric acid to produce electric current, but it's a spongy material that redissolves easily as the battery is recharged. If a battery sits in as partially discharged state for some time, the sulfate form a hard crystal which really resists the reconversion back to lead (negative plate) and lead dioxide (positive plate). That reversible chemical reaction can go on virtually forever, as long as it's done frequently. Jerry
