| | | Forums66 Topics128,180 Posts1,057,148 Members48,464 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2018 Posts: 44 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2018 Posts: 44 | Dear Friends: I brought a used 235 engine 6 months ago. It has all the accessories installed. I stored it upright in a climate controlled garage. There was oil in the crankcase. The crankshaft turned freely using just the fan and I last checked it 3 months ago. When I started to work on it this week end, , the engine is locked just as if it were bolted. Turning the damper with a pry bar fabricated for the purpose will not budge it either way, not a fraction. I pulled the pan and it is beautiful under there with an oil film covering everything. I pulled out the distributer and gear and removed the spark plugs and liberally sprayed in penetrating oil.
What could be causing this?
Best regards,
Joe.
'49 3100 "Sweet Caroline" because the truck has fabulous curves .... like Caroline!
Entire Thread
Engine siezed, rotated freely 3 months ago, what is cause?
| Joe S. | 05/28/2019 1:06 AM |
Re: Engine siezed, rotated freely 3 months ago, what is cause?
| Hotrod Lincoln | 05/28/2019 1:17 AM |
| Joe S. | 05/28/2019 1:39 AM |
| EdPruss | 05/28/2019 12:22 PM |
| Pre '68 Dave | 05/28/2019 2:09 PM |
| ApacheJr | 12/25/2021 2:28 PM |
| 52Carl | 12/26/2021 3:37 AM |
| DaveV | 12/26/2021 3:54 PM | |
