| | | Forums66 Topics128,088 Posts1,055,993 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,785 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,785 | It sounds like the carb has a porous casting or some other internal problem. There could also be an incorrect gasket installed somewhere or a missing check ball that's allowing the gas to siphon out of the bowl. If this is a new carb, and the symptom has been there from the beginning of using it, you probably need to contact the seller about a warranty replacement. Jerry
