| | | Forums66 Topics128,090 Posts1,056,016 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2010 Posts: 17 New Guy | | New Guy Joined: Apr 2010 Posts: 17 | Thanks for your replies. Here's more info that you asked for. The white wire goes to the hold down screws and the black goes to the centre stud of the sender. This was the configuration since I've had the truck and it used to work like this. The white wire is very brittle so maybe it 's broken somewhere. The problem is that the wires are inaccessible under the tank and I can only see the white wire under the cab, which goes into the loom so I can't see where it goes after that. I'll study the previous threads and hopefully I'll find out what the problem is and get back to you. | | |
