| Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,748 | Use pieces of exhaust pipe with a slice cut out and trim the length to fit the hole. It takes a little cutting and trying, but the sleeves don't seal vacuum. They only align the manifold so the gasket can do its job properly. Jerry
