| Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,958 | Some axle vents are incorporated into the bolt that holds the brass brake line junction block to one of the rear axle tubes. Those usually have a hose nipple for a rubber tube that ends up above the high water level of trucks that go off road. Jerry
