Bothe of my head lamps do not have a 3 prong connector going to them, and my after market dimmer switch with a little different connector locations and no 3 prong makes me believe my wiring installation could be wrong. I have been running it this way for a while but have been smelling some wiring a heating up as I am on my way to work in the morning. I know where the power is on the dimmer switch, now you have a high and low beam terminal, how do you determine that, and the head lamp ground terminal is the middle one I believe, now how do you determine the high and low beam to the headlamps? Thank you there Bolters...….
