I recently acquired a freshly rebuilt Zenith carb and a parts carb for my '48 GMC with a 228 engine to replace a old, leaking and tired incorrect Rochester. The rebuilt carb did not have the base drilled and tapped for distributor vacuum advance though the parts carb does.
The machine shop correctly drilled and tapped the boss on the carb but for the brass vacuum fitting but the small diameter hole that is drilled completely through into the carb throat is much larger than the one on the parts carb. I eyeball the hole diameter in the parts carb at 1/16" while the freshly drilled hole in the rebuilt carb is 5/32". I won't know for sure until I install the carb but it looks as though the top of the butterfly will be visible through the hole when at idle setting. That can't be good.
In my never ending quest to learn all sorts of stuff I never knew I needed to learn I have three questions. Does the larger diameter drilled hole greatly affect the vacuum at idle? Is there a related problem because the butterfly doesn't close completely above the drilled hole? Can I fit a restrictor into the threaded part of the carb boss to fix this?
I think I know the answers but I welcome, as always, your collective help! Thanks, Jim
