Possibly...
If the bearings were smoking hot the hub would have to be very hot enough to transfer heat to the axle flange. (the wheel bolted to the hub would also be really hot) If that happened I'd suspect the entire axle flange in contact with the hub would/should see the same temp and color change That is not what's shown with the outside portion of the axle flange being cool, no color. The color pattern indicates the axle shaft was the hot part and the heat didn't quite travel out to the outside of the flange.
I'd guess the colors on the axle shown are a result of the manufacturing process, tempering, and not an indication of previous severe bearing trouble.
Grigg
•1952 Chevrolet 3800 pickup
---All pictures---
