| | | Forums66 Topics128,127 Posts1,056,681 Members48,452 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2001 Posts: 96 Shop Shark | | Shop Shark Joined: Feb 2001 Posts: 96 | I used the engine mounts from chassisengineeringinc and they came with the measuremmments. They mount to the frame without the cross member. If you use the older smaller style dist. it fits fine but with the newer hei you will have to modify the firewall. If you move the engine forward you may have to go to the short water pump or a electric fan. I moved the stearing box back 2inches for the exhaust. you can use the same front end. I would upgrade the brakes. What transmission are you going to use? Good Luck | | |
