| | | Forums66 Topics128,099 Posts1,056,501 Members48,444 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2005 Posts: 2,099 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,099 | The original steering column and steering box are a complete assembly. In order to use the stock column you would need to cut the outer column tube and the inner shaft to separate them from the steering box. From there you would need to attach an adapter such as a rag joint or universal joint to the end of the shaft to correspond with the spline on the upper shaft of the new box. You would also need a bushing between the tube and the shaft and a bracket to hold the lower end of the assembly to the firewall. You could also purchase a replacement column from a later model vehicle at a wrecking yard or use an aftermarket column. Fred
1956 3100 Pickup/Red/350/3sp OD/PS/Disc Brakes 1957 Bel Air Sport Coupe/Red/355/TH350/PS/Disc Brakes 2017 Silverado LT Single Cab SB/Black/5.3/6 Speed Trans 1947 Willys CJ2A w/F-Head engine
