3 members (Woodcmiami, Cosmo, 1 invisible),
75
2
Mod | | | Forums66 Topics128,150 Posts1,056,991 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2018 Posts: 22 'Bolter | | 'Bolter Joined: Nov 2018 Posts: 22 | 52Carl, I idled it for 30 minutes before checking. #1 rocker weeps oil from the top, and from the bottom. Just #2 rocker doesn't weep from the top, yet does leak from the bottom, although slower than the rest. I'll turn up the idle to build more pressure to see if that changes things. | | |
