| | | Forums66 Topics128,162 Posts1,057,068 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2015 Posts: 914 'Bolter | | 'Bolter Joined: Jan 2015 Posts: 914 | On 1946 2 ton both adjusting bolts turned clockwise to reduce clearance between the brake shoe lining and the brake drum. Need to turn both bolts the same amount so both shoes grip evenly.
Also when installing new shoes the manual says to back off the parking brake before adjusting the brakes. Once the brakes are adjusted then you readjust the hand brake. Jeffrey | | |
