| | | Forums66 Topics128,049 Posts1,055,699 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2018 Posts: 351 'Bolter | | 'Bolter Joined: Aug 2018 Posts: 351 | The first three digits of the engine serial number that you see stamped on the pad by the distributor decodes it to a '52 Series 3100 216ci Truck Engine. See: Early Chevy Engine Serial Number ID. Based on your other post, the head is from a bit later model, '54-55 235 truck engine. I can't help with clutch info, but I'm sure others can.
