| Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,869 | The auxiliary parking brake was called a "Mico Brake Lock" and it was used with hydraulic brakes. The valve in the picture just a trailer brake control that has been repurposed as a wheel lock while winching a load. If you use it that way, keep the engine running to keep the air pressure built up. Jerry
