| Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,792 | A couple of pieces of pipe, some all-thread rod, flat washers and an impact wrench will make a field-expedient press that will remove and install the bushings with the same tool. There's no need to cut them to reduce the press fit. Jerry
