I believe Chevy and GMC doors are the same, but hopefully an expert in this area will chime in to confirm. Do you have access to an engine hoist? I have remove both of my doors to install new weather stripping by using an engine hoist. I lower the window down and run a couple large nylon straps thru the window opening and up to the engine lift's hook. I'm sure there are other ways and hopefully will jump in and give you more details.
Here's a pic of my door dolly:
[img]http://www.cmaynard.com/Truck/TruckDoorDollyB.JPG[/img]
Craig
