hi i'am working on a 1951 panel with a 235 from a 1957 car. sm 420 trans.
the motor has been rebuilt using a mild comp cams, dual zenith 28s with a edlebrock intake, and fenton duals.
i want to install the PCV system described on deve's tech page. and i have a couple questions regarding vacuum. first, i need to connect the distrubutor to a vacuum sorce. i have read various opinions on where this can/should be done. the problem i'm having is the zeniths don't have a vacuum port. so can i pull vacuum off the manifold for the advance? also, can i split that same vacuum for the new PCV or should i stick with the old style crank tube?
please be advised, this is new territory for me and thanks to forums like this, i'm finding my way but, if i've described something that sounds like i don't know what i'm doing well, i don't!
