So we’re finally starting the restoration back to 100% original on our 57 gmc 100 it’s a 2 owner truck and really solid I’ll post a few pics we gotta rebuild the stock zenith carb on the 270 and also rebuild the glass bowl fuel pump so any recommendations on anyone who can restore the carb and replate everything would be awesome we just gotta make sure the engine is good before we pull it to rebuild or just re gasket and detail it out. I got to the front suspension and there are some odd cylinders bolted to the spindle or in that general area there’s a lot of crud so hard to see. I’ve tried googling it and using the search function to no avail. The label says warning high tension road shock damper made in Dayton Ohio part # 5025179 I’ve asked everyone I know what it is and with no result. Thanks for checking out my thread I will post updates as we go through the restoration I also need a set of doors thanks again lady’s and gents Semper Fi
