9 members (Danielbolt, Charles in CA, SmalltownTRKGuy, Gdads51, Bill Hanlon, Peggy M, LAJones48, 3B, 1 invisible),
85
2
Mod | | | Forums66 Topics128,092 Posts1,056,455 Members48,443 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,829 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,829 | Unless you supported the area around each guide as you did the pressing, you've probably got a boat anchor. Ditto on the pressure test, and at least get the head gasket surface milled a little to be sure it's flat. Situations with long pieces of cast iron and ham-handed methods seldom end well. Straightening a bent cast iron crankshaft is done with a big lead hammer- - - - -not a press. Why are you making guides? They're available ready-made by the hundreds. Jerry
