In which way are you referring to?
Using the BW case from a 4 speed,, the answer is no, not at this time.
You can swap in other 5 speed units with some mods.
There is enough good in the worst of us and enough bad in the best of us that it does not behoove any of us to criticize the rest of us.
Be yourself. If you are ever lost, It will be much easier to find yourself if you know who you are!
