| | | Forums66 Topics128,030 Posts1,055,424 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2015 Posts: 11,004 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,004 | Most of the patch panels are identical no matter where you buy them. I've gotten some good stuff (TriPlus brand) from RockAuto for very good prices. Better than from some of the well known vendors here. Just about everything is made in Taiwan, so you can pick from offshore or offshore. I have a rocker panel from a well known vendor and one from RockAuto, and the differences are negligible as far as thickness.
