| | | Forums66 Topics128,012 Posts1,055,318 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2015 Posts: 10,997 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 10,997 | Very likely, there will be internal pits on the outside skin. You may burn thru when welding at the seam, but you should be able to get it fixed up. You should consider sandblasting first before attempting repair. That will show the true nature of the rust extent. I don't know of an inner door patch available, which would be your best option if you can find one.
Good luck.
