Read my POST in your "rear end ID" THREAD
Someone installed a open driveshaft axle on to your 1951 1/2 ton panel.
But they must of used the original torque tube / closed driveline leaf springs and performed THIS TRICK and flipped the leaf springs.
The leaf spring center bolt on trucks that originally used a torque tube / closed driveline, is offset to the front. (check attached photo)
The center bolt is not in the center of all the leafs, it is offset to the front.
The bolt is in the center of the bottom leaf, but not in the leafs above.
Read this POST for more clarification.
xfiles
