Thank you for the response. I know everything that will work on a half ton truck. But can I use the 60" rear end on a 3/4 ton AD? I know the 3/4 came stock with a 52" rear. But in theory if the box is the same width as a half ton it shouldn't matter, right? Maybe I'm missing something.
Brandon
