7 members (Shade Baby, Pete1946, frogfarmer, baldeagle, 1955 1 Series, Jon G, 1 invisible),
97
8
Mod | | | Forums66 Topics128,106 Posts1,056,213 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,801 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,801 | I believe the Speed-Pro hypereutectic cast flat top pistons with the Teflon skirt coating for a 283 V8 are a drop-in fit for the 230 like the same design piston for a 307 fit the 250 engine. The 194 cylinder head has more compression, but it also has smaller valves, IIRC. I'm in the planning stages of building a high-RPM 230 with NASCAR tool steel connecting rods and three side draft carbs to put in an Excalibur fiberglass roadster. I'm considering destroking that one to get down around 200 cubic inches and increase the RPM capability. Jerry
