| | | Forums66 Topics128,041 Posts1,055,479 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2009 Posts: 54 'Bolter | | 'Bolter Joined: Jan 2009 Posts: 54 | I've been reading different posts about which type of seal is better, umbrella or o ring. Can someone explain how each one works? Does the umbrella just got over the valve guide or in the groove where the o ring would go? If I use the o ring type does the retainer slide up and down over the o ring? The ones in the head gasket set are bigger than valve stem is that normal? I haven't dug this deep in an engine before. Thanks for reading. | | |
