| | | Forums66 Topics128,014 Posts1,055,328 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2003 Posts: 1,061 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 1,061 | 3B and HRL, Thanks for the education. This confirms my thoughts on the need to do this and explains a process that should not be left to the new guy in the shop. The timing chain gear and chain, is perfectly logical, but not something I would have thought of. I had this done on the 216 from hell and it was probably not needed. And most likely contributed to the trouble I have with that engine. Thanks again.
1946 1-ton Panel 1952 1-ton Comml. W/Grain Body | | |
