| | | Forums66 Topics128,080 Posts1,055,951 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,780 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,780 | A Powerglide for a car 235 would be a bolt-on installation, assuming you can find the right flywheel (flex plate) and the adapter ring that bolts onto the block. Powerglides have two speeds- - - -"Too low and too high!" The only other bolt-on would be the 4 speed dual range Hydramatic- - - -scarce, expensive, and difficult to adjust the throttle linkage for proper shifting. There are vendors selling adapter plates for transmissions like the Turbo 350 and 400, and the 700R4, etc. The quality of those items varies from mediocre to excellent (Translation: E$$$$PENSIVE!)
Putting a "Belly Button" V8 in place of a good-running 261 is a huge leap in the wrong direction. Jerry
